found out whats wrong with rear upper control arm **PIC**
k99jk99j
ohio
well i took the arm out to replace it and found my clunking and creeking source. the boot for the rear ball joint is degrading and letting moisture in.
i replaced it with the aftermarket option from orielly auto parts and all my noises are gone!
start to finish it took me 2.5 hours, removal and installation. mike
bugnout
Illinois
After market ball joint or did you replaced the entire boomerang?
k99jk99j
ohio
i replaced the entire boomerang. cost $200. part # CB28013. it is an exact copy of original down to holes and ovals in the stamping. also the same exact harware (10mm bolts with a torx inlayed into the head) was used to hold the parking brake cables. the two units side by side look identical. even the same #'s stamped into the sheet metal.
the only difference in parts was the aftermarket had a blue boot around the balljoint. the original had a black boot. mike
rockymountain
Spencerville, IN
hmmmm. possibly a moog balljoint?
never used one from there before have used some other aftermarket ones that looked the same and they only lasted about 12-15,000 miles
Keep everyone posted on how yours works.
When I moved I had 6 used ones laying in the corner, the old neighborhood junker dude loved me plus I gave him a whole 8.25 rear diff :happy175:
dtschro
illinois
rear ball joint
have same issue with 02 liberty ., however , after crawling under to take a look at it , discovered that bracket that holds a arm and ball joint to diff was cracked in half at bottom bolt on diff . also discovered that one of top bolts was backed out about half way . i am going to replace bushings and ball joint , but any ideas on where to find that bracket ?
thanks
ridenby
Gold Supporter
Kentucky
thanks
A salvage yard?
Snail Farmer
Fairmont, MN
thanks
Mopar Online Parts: Repair Parts
Enter your year and model, click on rear suspension, it'll open a drop down, click on rear suspension again, then click on upper control arm. For your year it's $111.49 for the Dana axle and $196.65 for the Chrysler axle. Or a salvage yard like Ridenby said.
The bracket is the same for all years
I have one from an 02 , another from a 06 ( spares of course :whip:) and then of course the one on mine and all the same
dtschro
illinois
Ball joint bracket
Anyone know where i can find rear upper ball stud bracket for 02 liberty ?
Dealer wants 285 bucks
k99jk99j
ohio
btw this rear upper control arm is still holding up good!
well i spoke too soon (egg on my face). had a clunking in the rear that was not resolved by the recall on the lca's. so i took the 1 year old upper rear control arm out to inspect the bushings. here is what they looked like.
mortified i went and bought the mopar one at the dealer and it's bushings look more beefy.
put it back together and my clunks are gone again.
this aftermarket part from orielly's came with bushings that did not even last 18 months! so obviously if you are in the market for a rear upper control arm the dealer looks like the most quality part!
mike
p.s. my kj has a 6 speed manual trans,could this cause more stress on these bushings?
that looks like a candidate for the ol' windshield urethane mod.
J-Thompson
just south of doucheville
If this is an ongoing issue for the KJ
Why not fab up your own?
Truss/LCA mount for a TJ on the top of the axle
Beefed up for the added stress
For the UCA
Large "Johnnie Joint" on the axle end
Stardard TJ lowers at the "frame end"
Modify the frame end of the KJ
Problem solved
New Liberty
Ottawa, Canada
Recall?
I received a recall notice last week, and if I am not mistaken, it's for the rear upper control arm.
We're in the middle of moving/renovating, so I will have to check to be sure when I get home.
k99jk99j
ohio
i also received one last week for the lower control arms, just had mine completed before i replaced the uca.
mike
Knew it wouldn't last Like I said before tried the cheap ones and they are just that
Buy the regular Mopar one and be done
