Brakes...
-=JoN=-
67°20'N 14°40'E
recommendations?
going to replace them...
probably will get satisfied pro brakes, but just want to see what everyone elses opinions are
Bennett
Active Member
Green Bay
Bendix - Awesome stuff. I put satisfied on another car and I'm so sure about them yet, but they work.
rockinkj
Desert Southwest
I like the "Carbon Metallic" brand for pads Used them on a '02 Libby, and before that on a '88 S10 Blazer, and a Chev 1ton. They wear like iron, and also cause very little wear on the rotors. Excellent high temp performance too. I'll never use another brand again.
One thing i heard about the Carbon Metallic is they tend to heat up and warp the rotor, there bad to warp anyway. I really want to get those b/c everyone says they brake really good and I tow but i dont want to get new rotors at $100 a piece (power slot).
rockinkj
Desert Southwest
Never heard about the rotor warping problem with CM, and I can't figure out why the rotor should get any hotter with one pad over another, given the same amount of braking effort. In any case, the 1ton Chev was my motorhome with CM pads on all four, loaded to GCVW and then some. Never had a rotor problem, and since I'm a west coast dweller I used (abused) the brakes plenty hard sometimes.
