2006 key turns to accessories but no power (no click sound)
TahirTu
Riyadh, Saudi Arabia
I noticed all of a sudden that when turning the key back for the accessories positions, they key turns but no sound of the usual click and nothing gets powered, Otherwise the key cycles to all positions normally and the jeep stars no problem however I noticed when shutting off, the the key turns out of run position kind of loosely (not as the usual) and sometimes when getting out of the car and pulling the key out it keeps beeping as if the key is still inside, it goes away when inserting and removing the key again.
I'm wondering if anyone has experienced this before, and would give advice to help pin point the problem.
Sounds like the ignition switch itself is wearing out.
Once something is not not working correctly with the ignition, it is best advised to completely replace the ignition switch.
If by chance the actuator pin breaks, it can leave you completely stranded, by not allowing you to start the Jeep again.
Id get a new actuator Dorman # 924-704 installed as well, to be on the safe side.
I would recommend a new Mopar ignition and find an automotive locksmith to re-key the tumblers.
This video from a Pt. Cruiser helps to explain components of the system and how to access.
CRD28
Starter motor solonod or starter relay
Fuses are down the side inside open left or Right hand drive. Door pull off panel
Other fuses are under the hood by the battery
TahirTu
Solved
The problem was in the ignition actuator pin that had broken tip which affected how it engages with the ignition switch, part is located below the steering wheel, you have to remove the steering cover and lock cylinder, ignition switch. replaced the part and it was all good.
