Window stopped working
JBDive
NC
Drivers side, rear window just stopped working. I do not hear any motor sound form the regulator at all. I have not pulled the door panel as of yet. All other windows work.
Ideas:
1. Front window 4 way switch?
2. Regulator
3. wiring unplugged or other
4. Good luck figuring it out
Just trying to narrow down what I am going to tear apart first.
kejobe
NE Ohio
More than likely its the motor. Pull the door panel and check for power on both sides of the plug (door side) when hitting the switch. If there is power, the motor is bad. If no power than probably the switch.
The power and ground flip wires depending on whether the switch is pressed for up or down.
To further verify the motor is bad, string a couple wires, one from power, one from ground. Touch them to the motor side of harness. If nothing happens, flip the wires. If still nothing, the motor is defiantly bad.
