window regulator
knucklebuster
Mass
Replaced the rusted out front passenger door on my 2007 liberty with a 2002. The 2002 regulator cable broke loose from the riser. Does anyone know if the regulator from the 2007 will fit in the 2002 door?
Thanks,
Tom
GunnerSchenck
My box with my extra regulators for the front says 02-04, but I don't think there's any change in the design.. I believe you can, if there's a different connector on the motor, just splice the old one back on..
Should be pretty easy though
kenM420
Pennsylvania
knucklebuster
Mass
I removed the regulator from the 2007 door. I think it will work in the 2002 but I'll have to swap the riser. The one on the 2002 looks a little beefier and has two tabs that go through two holes in the glass where the 2007 only has one.
Thanks for replying to my post.
