Whitish Smoke only at idle
FaustusCaligula
Plymouth, NH
So, My liberty has (according to the Meineke guy) an oilpan gasket leak. Car doesn't leak when it's off, just running. Averages a quart or two per 500 miles. Still runs fine, no loss of acceleration or anything. I've been sure to check my oil every day and worst, every other day. I don't let it run too low. I just can't afford $400 for an axle drop/Engine lift for the gasket change right now. $5-$10 for a bit of oil is much easier to cope with.
Problem is, now I'm seeing a bit of whitish exhaust at idle. When Running, there's no issue whatsoever. Exhaust is normal. But when idling even at lights, the exhaust is noticeably white. I'm also smelling burning oil every so often.
How bad could this be?
FaustusCaligula
Plymouth, NH
Ever since I've gotten it, I've put in High Mileage synthetic if that makes any difference. Specified for that at Oil changes as well.
Conundrum2006
Alabama
I doubt the pan gasket is leaking. The way it works it very unlikely to suddenly leak. Valve cover and crank seal (and rear main) are more likely.
White smoke is usually coolant related. Now bluish would be oil.
I'd check the fluid levels and see whats happening over time.
