Where's the SIRIUS antenna? Song info on display??
hummingbird_206
Seattle, WA
I picked up my new KJ (Limited) last night and I love it! I got the in dash 6 disc cd changer with SIRIUS radio. I read in the OM that you shouldn't put anything on the roof over the antenna, but I can't figure out where the antenna is located! Can someone tell me where to look? I plan to use a ski rack sometimes, and I would expect that the skis will be longer than the roof, so should I let them hang over the front or the back so as not to block the antenna?
Also, I've read several of the posts about no song info on the display. I get the channel type (Rock, Pop, etc.) but don't get the song info. I'm a bit confused by the posts, should I get the song info with the factory install, or do I have to get the dealer to add extra hardware, if so, how much does that cost?
Thanks!
Gentleman
8' Below Sea Level
The antenna is on the rear roof just forward of the high mounted stop light, for 06 it is a lot smaller than previous years, the only radio that will give you the artist/title info is the RB1 navigation radio
