Wet floor
Tog
AU
Noticed today the floor directly in front of the front passenger seat(Aussie kj) is wet
has anyone had this before it is only the area within the red circle on the image. I cant see any dripping water or anything like that the weather is dry as so no rain is getting in im lost and open to ideas
Sent from my SM-G930F using Tapatalk
teeje
Toledo
Remove the seat, and the trim pieces and pull up the carpet. Odds are it's the hole the seat bolt goes through is rusted and is letting water in. Not common but it is possible. The seat bolts go straight through the unibody
You got three 15mm bolts and one 16mm nut in the rear of the seat. Keep us posted
Tog
AU
Ill take a look at that
teeje
Toledo
Update.
Or it could be running down the a pillar and under the trim which would be why you're not feeling it anywhere else. Start by revising the seat and trim pieces first. They pop right out easily
check A/C evap drain.
There should be a 90 degree elbow that points downwards coming out from the firewall on the passenger side.
Tog
AU
Yep i guessed that was the case
Tog
AU
Ok so the seat bolt is rusty but not rusted through the foam underlay Under the carpet is sodden and by the looks of the rust showing it has been for some time. Gotta check the ac pipe yet
