The HD's electric fan and the standard electric fan are different, so it will be interesting to see what happens if the viscous fan is removed from the HD.
By the way,
My 2003 model has right-hand threads.
I think other model years are probably the same as long as the engine rotation direction and the serpentine belt route are the same.
Stand facing the front of the car and turn it to the left to remove it.
If you insert an M6 bolt into the hole in the pulley and hook it onto the rib on the pump housing, you can turn a wrench with both hands.
