Unclog windshield washer nozzle
Damotee
Cape York, Australia
I drive on dusty roads fairly often and as a result my windscreen washers are almost completely blocked. The water just dribbles out. Does anyone know an easy way to unclog these? Thanks
Ya dusty roads and droppings ..ha ha..:gr_grin:
60402[/ATTACH]"]
A nice medium sized sewing needle should clear nozzles out!
Royy
Western CO
You can also use an electronics duster, if a needle doesn't work. It's basically just a small can of compressed air, with a straw that you can bend to get into hard to reach spots.
kejobe
NE Ohio
I'd remove them first. Then use a needle to clean them and blow them out from the spray end to the hose side. Otherwise when you clean them, you'll be pushing the dirt into the hose area and it will just clog up again shortly.
