AlexKJ
Much has been said (and never with a single fact) about the superior strength of the Command-Trac (NV231) over the Select-Trac (NV242)...
Well... I still can't prove otherwise
... but! I have found something interesting in Wikipedia (I know... I know... everybody can write anything blah blah blah...)
Anyway... The article says that the nomenclature of the New Venture Gear transfer cases it's as follows:
NV: New Venture
Number of Speeds/Gears: 1 = High range only, 2 = High and Low
Strength: 1 (low) to 7 (high)
Type:1 = Part time, 2 = AWD, 3 = Electronic shift, 5 = Torsen dif., 6 = Computer controlled wet clutch, 7 = GeroDisc, 9 = Viscous coupling
Soooooo what do you have to say now?... you weaklings!
(obviously a j/k)
The real question is ¿do you think this info it's accurate?... I have my doubts... It's says nothing about what stands for the 'OR' in the Rubicon's Rock-Trac (NV241OR) or the 'J' in the Command-Trac HD (NV241J)
NV: New Venture
