trent.brown
When it rains it pours, in addition to my passenger window that won't roll down, ac not blowing through proper vents, check engine light for incorrect purge flow, locker still making noise, and stereo not playing out of the right side, now my transfer case is slipping out of 4lo into a kind of 2lo with what sounds like gear teeth not aligning.
Anytime I'm in 4lo and put some torque on it, it will bang then make the out of sync sound. Out of all my searching I have determined it is probably the chain stretched or shift fork bent.
My liberty is a dd but I only live a mile from work. Running to work wouldn't be a problem as long as I didn't do it too long.
So my question is if I can get a decent nv242 from a wrecked durango or other vehicle for around 100 dollars, would it fit? I am assuming that all nv242s and np242s should be the same except for spline count which I could use my current input and output shafts.
