Transfer Case Shift Cable
chris03kj
Chicago
Last night I broke the t-case shifter cable at the handle, i bent the gold part with the green bushing, how, i don't really know. At least, I believe it is broken because the green bushing where it would connect to the shift handle is bent at a 90degree angle. after manually shifting out of 4lo by using a hammer, i was finally able to drive home. So, i need a new t-case shift cable. Does anyone know how hard it is to replace the entire cable? my entire interior is taken apart already, I'm more concerned about the brackets under the vehicle, if i can just get the cable out of them or if i have to take the whole bracket out.... any idea?and does anyone know the part number of the cable itself?
blackhawk
Venezuela
As far as I know the whole shift handle comes along with the cable. The cable is not serviced!
projectkj
Ontario, Canada
i did this exat same thing trying to remove the motor, i shifted the tcase into neutral and snap.... right after the handle.....
2 bolts on te transfercase, and a clip holding the cable to the tcase.. a few bolts under the console...
looksl ike im going to the wreckers.....
hope i get there before i starts snowing...
