TPMS in spare tire?
Every time I start the KJ, I get an EVIC message that the spare tire pressure is low. I thought that was weird considering there isn't a sensor there, right? Thoughts?
Thanks
Mthigh_Freak
Check the spare pressure, if its low then you probably do have a sensor in there and you should air it up! :waytogo:
There is a sensor in the spare too. Air it up and the EVIC message will go away. ..:smokin:
Oh there is? Good...thanks everyone. Guess I should of checked it in the first place. :D
kev92gt
st. Louis
Put almost 60 psi and the dang sensor won't shut off. 2005 3.7 limited. Any thoughts?
ryanee182
Rochester, MN
I thought I remember reading that if the tires pressures vary by more than 5 or 10 psi, the light will turn on. Or if there is too much psi. Try making sure that all 5 tires are at the same psi?
blue_kjR417
Platinum Renegade
Jonesboro, AR
No luck is there a reset or can I disconnect battery?
There is no reset, other than starting the jeep and driving it down the road for a bout 3 mins. That is supposed to clear the system, no other process will. If it still doesn't clear after that, your sensor may be bad.
kev92gt
st. Louis
on a 05 liberty limited are the wheel covered with a plastic material?
ivantate
Illinois
Mine beeped at me for days after having the spare replaced and getting one which held air. I even swapped with one of the others and it made no difference.
Then suddenly it stopped warning. All good now.
