Timing belt or timing chain? A noob question...
rhinoculips
I am looking into buying a Liberty and can't seem to figure out if they have a timing belt or timing chain. Whats the recommended replacement interval?
ThunderbirdJunkie
Bronze Supporter
Newport, KY
2.4s have a belt, CRDs have a belt, 3.7 V6s (which are the only engines in the KJ that are worth a damn ITBJHO) have a chain
2.4s have a belt, CRDs have a belt, 3.7 V6s (which are the only engines in the KJ that are worth a damn ITBJHO) have 3 chains
Fixed it for you:D
The 3.7 has no change interval for the timing chains,the 4.7 v-8 which uses the same setup(identical stuff) have been going well over 250,000+miles with the OEM chains and it's the tensioners that need to be changed before the chains.
incommando
SW Ohio
Reading around the net, it seems that changing your oil regularly with a quality oil is very important for tensioner longevity. This is true for most any modern engine due to the tighter tolerances. Just throwing this out.
kb0nly
Planet Earth
3 Chains?? Ok i guess i'm space casing it here... I thought it was just two, what am i missing?
ThunderbirdJunkie
Bronze Supporter
Newport, KY
ITBJRC one goes up to a dummy cam in the block like on a GM 3.4 DOHC or an old Taurus SHO V6, then one to each cam
valvestem
Northeast US
Like this I believe...
1 - RIGHT CAMSHAFT SPROCKET AND SECONDARY CHAIN 2 - SECONDARY TIMING CHAIN TENSIONER (LEFT AND RIGHT SIDE NOT COMMON) 3 - SECONDARY TENSIONER ARM 4 - LEFT CAMSHAFT SPROCKET AND SECONDARY CHAIN 5 - CHAIN GUIDE 6 - TWO PLATED LINKS ON RIGHT CAMSHAFT CHAIN 7 - PRIMARY CHAIN 8 - IDLER SPROCKET 9 - CRANKSHAFT SPROCKET 10 - PRIMARY CHAIN TENSIONER 11 - TWO PLATED LINKS ON LEFT CAMSHAFT CHAIN 12 - SECONDARY TENSIONER ARM
kb0nly
Planet Earth
Ahh interesting... Didnt know that as i haven't looked through the engine part of the FSM yet.
