Timing belt kit?
ElCheapo
Erie PA
Planning to flush coolant system and replace the timing belt/water pump soon, the kits I see come with belt, pump, tensioner, idler, and you have a choice of bracket or no bracket. I'm guessing it's best to just get the bracket? What about cam, crank seals?
Gates, Dayco, GoodYear, or other?
Wish I knew more about the 2.4 but don't. As for the brands, I've used them all at one time or another. I'd probably go for the Gates but haven't had any problems with the others. I did my crank seal when I did my headgaskets las spring and went with a Mopar. I had a whole timing cover set that came with one but opted for the Mopar after reading some suggestions on here.
ElCheapo
Erie PA
I'll need to do some inspecting to see if they are leaking, if not, won't bother with them.
