Think this could be modded to work well?
TAwesome
Pizza Pimp
Grand Rapids, MI
Clyde Frog
Central Mass
The light bar uses two side 3M tape to stick to the roof.
I trust 3M two sided tape to hold on my tail light guards but certainly wouldn't trust it to hold on my light bar.
TAwesome
Pizza Pimp
Grand Rapids, MI
Ahhh so you read the description I was speaking of. Yeah that is one of the mods that i'm think would have to be done. 3M tape changed out for reataining clips of some sort.
Clyde Frog
Central Mass
Even then it might be iffy. I just worry about cold/hot weather cracking the clips or wind from driving ripping the light bar off. Unless you can find a way to drill baby drill to attach that light bar. And even then, like HJ said, it looks like China junk so it might be less than spectacular plastic.
Even with clips, the plastic on the bar it's self would become brittle...and from there, some nice winds could rip it off the clips.
In the words of Tommudd:
"Cheap is expensive."
Which at least to me is true.
Marlon_JB2
Kombat Edition Jeep
Harrison Township, MI
i can't believe someone would actually take the time to create that horrible junk. those stupid clear tail lamps look better.
avoid it like the plague!
kjweston
Boca Raton, FL
yeah stay away from that.. I had my lightbar on with 3M before I installed it per mopar specs. And it flew off going 60. almost cried.. watching $500 slide against the asphalt behind you. plus it doesnt even look like that is long enough to look good on your roof. better off making a bar and putting some hellas or PIAAs on it.
