Steering Wheel Vib
KJJosh
Northern VA
As everyone knows I just installed a lift and have a small issue. The steering wheel vibrates at speeds over 50mph. It isn’t a major vibration more of a minor thing....
It has been to the alignment shop 3 times now and had the tires balanced twice. The second balancing made less noticeable...
Is it the tread on the A/T's that I'm feeling or is something wrong????
J-Thompson
just south of doucheville
No one can say with out driving the Jeep
I really doubt that the tread on such a mild AT would be what you are feeling
I would roll the tires front to back OR pull 1 front and install the spare
if problem persist then remove the other tire leaving the spare and installing
the first removed tire
You could very well have a bad tire ,I had 1 of my MTR's go bad
but I just put it on as the spare
ptsb5a
Northern Alberta, Canada
I'll agree with Mr Thompson here. Could be belt seperation. But you'd think that it would be visible during the balancing.
Spidey
Charlotte, NC
Get under your Jeep and grab the CV axle "cups" where they go into the front axle and wiggle them up and down, if there is a lot of play this might be your wobble. I just replaced my front passenger CV axle and inner shaft and that took care of my wobble AFTER trying everything else.
kj924
Prince Edward Island,Canada
Did you get a bad brake pedal vibration when on the brakes?
ThunderbirdJunkie
Bronze Supporter
Newport, KY
Alignments DO NOT CAUSE VIBRATIONS (we need a sticky that says that)
A: bent wheel
KJ's stock steelies are weak and when they bend, the whooooooole thing is BENT. More of a wobble-side-to-side feeling.
B: out-of-round tire
Common on Firestones and other budget tires. Even new, yes.
C: You had a less-than-stellar shop align your Jeep, and they did NOT check your tie rod ends before aligning.
Stupid of them, because that's more potential money in their pocket.
D: CV axle issue.
***** bro.
Not always. ThunderbirdJunkie had a belt separation in an MT/R that was not visible on the balancer, but was felt in the steering wheel and seat above 50. When that tire went to the tailgate, it magically disappeared:D
KJJosh
Northern VA
Well I guess I'll be taking it back to firestone in the morning..
TBJ how do you check tie rod ends??????
The jeep has 57,000 miles on it. Do CV still need to be checked???
ThunderbirdJunkie
Bronze Supporter
Newport, KY
Jack up the front end and wiggle the tire back and forth horizontally as if it were steering. If you feel play, then you have either inners or outers loose. This will later be determined.
ThunderbirdJunkie thinks, however, you have a 99.99999999% chance of having a crap tire on there.
Spidey
Charlotte, NC
Not really, I mean the wobble could be felt all-around and not just at the steering wheel but I didn't notice anything specific to the brake pedal.
Clyde Frog
Central Mass
My KJ had this problem and we found that both the rotors and my tires were bad (yay warped rotors). We did a 5 tire rotation, alignment, and balance but nothing helped. I got 4 brand new tires and all new rotors and it eliminated the issue. I think maybe the steel belt might have gotten screwed up because it sat for the summer on the lot, but who knows. I don't know much about mechanics about a car but maybe you might be having a similar bad tire issue if the tires are defective.
During this whole crap fest, I heard almost a sort of wobbling/muffled washer machine-like noise that sounded like it was coming from the front left tire no matter which of the 4 tires were on there.
Just as a note, I'm all stock so it could be a completely different circumstance (and probably is :p) but that's my $.02
KJJosh
Northern VA
When balancing a KJ tire and rim should it be balanced using the hub centric adapter or the lug centric adapter? What about a Road Force Balance?? I'm trying to educate myself when I go to war with Firestone on monday.. smashfreakB.gif
ThunderbirdJunkie
Bronze Supporter
Newport, KY
Road Force balancing doesn't matter, because nobody seems to know how to use the machines properly anyway.
If you have the chrome-clad wheels, they can be a ***** to center up...but not THAT hard. The KJ's wheels are hub-centric anyway, which is the way almost any shop will balance all tires (whether it's right or not)
KJJosh
Northern VA
An update....
I'm still fighting this issue and finally had time to get it looked at. The shop found "run out" in the front axles.. When they had it on the lift you could grab the wheel bearing and move it around with little effort on both sides.
The shop is recommending that both axles be replaced (CV joints correct?) Does the intermediate shaft need to be replaced as well or just the CV's? Is it normal to be able to move the axles like that...
Extended warranty people will be at the shop in the morning to approve this repair... If they deny it because of the lift do I have any recourse???
KJJosh
Northern VA
Yeah pay the bill.
Ok I guess I wasn't clear when asking... Would the Magnuson–Moss Warranty Act apply here if they deny the claim?
Here is the reason im asking... I modified the suspension the CV's are part of drivetrain.. Drivetrain and suspension are to seprate componets correct?
No the MM act will not help you,lift it and they can rightfully deny anything in the suspension and drivetrain due to being over stressed and not in normal operating ranges.Clearly stated in any warranty paperwork.
The lift wears out bushings,tie rods,ball joints,CV axles,u-joints,and bearings faster then normal,that is fact and they know it.
The bigger tires(heavier) you put on after the lift puts more strain and shortens the engine,trans,t-case,diffs,brakes,and bearings life,again that is fact and they know it.
They can not deny stuff like a failed wiper motor if your lifted,that is the purpose of the MM act.
ThunderbirdJunkie
Bronze Supporter
Newport, KY
MM act also does not cover aftermarket warranty coverage; only manufacturer-backed warranty coverage, like Chrysler's 7/70, Lifetime warranty, or their current 100k mile warranty.
