Springs + Spacer
Jeepkj
Churubusco, NY
this may have been anwsered already if it was i am truly sorry its just i get bad headaches from looking at the screen to long lol and i was wondering if i could use a coil spring lift with a spacer lift such as the rock krawler or daystar lift??? again if it was anwsered i am sorry
one more thing the OME 790's that are for bumpers and winches and such will it hurt to use them stock because i plan on a bumper and winch in the future
Thanks
Nope...can't without doing some major stuff. You can add a top plate, do the clevis lift, and add two isos per side in the rear.
For the springs, 790 is the HD for a CRD. That's going to be very stiff until you put some weight on it. If it's going to be more than a year, I'd wait or just get the 927's, and sell them when you get your bumper for the 790's. They should sell, people are always looking for good used OME stuff.
Jeepkj
Churubusco, NY
now with just the OME and say Bilstine's i am kinda parctial to Bilstines always have made a nice product how much lift am i actully going to get and would i be able to fit 31-10.5-16 with no wheel spacers or can i go bigger??
You'd probably want to add the top plates/clevis lift for those. You can fit a 30.5" (give or take a bit) without major trimming.
twack
rochester mn
you can run spacers and spring (light duty) if you shorten the coil somewhat. i wouldnt recomend this setup from the get go but its what i run. i just happen to come int to this combination of parts and made it work
