Speaker Discussion.
minimorris77
ILLINOIS
So hopefully soon ill be getting a new sound system. And have some questions. Whats the factory radio's RMS? If I go with a component setup do I need to run new wires? I took the door boot off once and it was a PITA to get back on. How would you run the wires anyway because they're connectors and you cant just slide a wire through? Also I read that the dash speakers aren't really tweeters because they're wired in parallel. Do I replace with full range speakers with a bass blocker or...? Also if I run coaxial speakers do I keep the ones wired in the dash? If I did wouldnt the two speakers in parallel make the two speakers have lower resistance? I don't want to amp my speakers, and probably wont get a sub. The stock system just plain ***** imo.
cplchris
Albany, NY
here is my suggestion:
go with a good quality component setup for the front speakers. mount the crossover in the front door, run the xover off of the factory wiring, then run a wire for the tweeter back through the boot between the door and a pillar. replace the dash speakers with the component tweeter and leave the factory dash speaker wire disconnected. you can fit a wire in the boot under the factory harness connector....if you choose to go with a coaxial setup I would find a good replacement for the dash speakers as well and not bother with a hpf on them. I have components in the front and rear that I run off of an pioneer hu with an alpine amp.
minimorris77
ILLINOIS
I now think ill defiantly go component. I was thinking of intercepting the door speaker wires before they went out the boot, just wire it inline, and mount the xover In the kick panels. Then just run a wire up to the tweeter. Is it possible to do a 4 ohm component setup in the front and keep the rear with stock 2 ohms? Probably set the balance more forward to balance the sound output? Also what gauge speaker wire for hu power?
cplchris
Albany, NY
as long as the head unit can work with a 2 ohm setup you are good. as far as cutting the factory door speaker wires: that is a no-no. i'm not saying it won't work or nobody can do it but a good rule of thumb is to never mess with any part of factory wiring. if you want to mount the xover under the dash the i would run a new dedicated line off of the new head unit. (make sure you buy a pigtail adapter for the jeep rather than cut and factory wiring). there is a surprising amount of space under the dash. i would zip tie the xovers in place rather than putting a screw in anything under the dash and risking damage to something else.
