Sentry Key shows up and jeep will not turn over
Soules3
I have a 2004 Keep liberty sport. I did a heater core change out. Once everything was back together I attempted to start it, but it will not crank. A key slashed out is showing up on the dash (Sentry Key?) Is that why I am having issues? If so, is there any way to reprogram?
timgray
Yep tow it to a dealer or locksmith and have them use their tools to reprogram it. Locksmith will havet o have the security pincode. if you dont have that the dealer will sell it to you for $60
Do you have two factory Keys? If so try the other key..
Billwill
White River, South Africa
You must have bumped loose a connector or damaged a wire.
No point in re-entering the SKEES number.
Does the ASD Relay energize?
The engine should crank...but not fire...no matter what the SKEES is doing.
Remove the Starter Relay and identify pins #30 and #87 in the empty female slot. With the Jeep in Neutral and Park, briefly jumper out those two female pins...engine should turn over.
