Seized upper control arm bolt. Attempt to remove it myself, or admit defeat and take it to a garage?
jamesbeat
New York
I am trying to replace the passenger side upper control arm on my 2005 Liberty.
I have done the driver's side one before, so the passenger side seemed like it should be easy in comparison, because the bolts are much easier to access.
I removed the nuts from both bolts, and got the front bolt out easily, but I can't get the rear one to shift at all.
It appears that what has happened is that the bolt has become seized inside the inner sleeve of the rubber bushing. I can move the control arm up and down, but it is very stiff, and I can feel that the inner bushing is staying still as the rubber part moves around it. The bolt rotates a few degrees as I do this.
I have tried all sorts of things, but I can't get it to move with the tools I have. I don't have a torch or an air hammer etc. I do have an angle grinder, but it's too large fit in the small pocket that the control arm ends sit in.
I'm thinking I could buy a sawzall and cut down either side of the bolt from inside the wheel arch, but it's possible I might end up just damaging it, and then I won't be able to drive the Jeep to a garage safely.
So, is a sawzall pretty much guaranteed to work, or should I just drive it to a garage and have an expert take over?
Jeremy-WI
Home
A sawzall will work but you will be bloody. The stroke on the sawzall I had was a bit long for the space on top of the blades being longer than I wanted. I lost count of the blades I destroyed doing the drivers side rear bolt. The passenger side freed up after a good soaking in penetrating oil but the rear on the drivers side put up a fight. A 3/4" board attached to the sawzall shoe might help with the stroke length as I finally used a piece of 3/4" hose.
If you can get in with it an impact driver is probably the best thing + lots of plus gas or similar.
Deb'nKJ
What Luke says makes a lot of sense.
PlusGas? Didn't know it was still on the market!
I've got 2 sawzalls & a whole selection of blades but never been able to cut more than sheet metal (& my jigsaw's better at that) not bad for pruning trees though.
I've got a makita recip saw, with a decent blade it's nearly as quick as an angle grinder but way less messy, I cut an old axle up with it the other day, took minutes to make it into 3 slightly less back breaking bits to dump in the metal skip. I use Lenox blades, handy for ripping pallets too, slice through any nails that would destroy my chainsaw's chain.
Plusgas is still available, Screwfix stock it, along with Arctic spray, I highly recommend that, it's helped me shift some horribly tight nuts and bolts.
belvedere
SD
I am going through this now. I have dulled 3 blades so far (expensive blades...Diablo Amped Steel Demon), and I'm only about 2/3 through the sleeve/bolt. My arms hurt, and my wallet does, too. Has anyone found a blade that works better?
Drop the saw speed and don't press too hard and your blades will last much longer a bit of Rocol helps too.
Shankster
Durango, Colorado
"Where there's a will there's a way". As others have said, it might be painful and take an hour or 2 but you'll get it. The tip of the blade hitting the back of the pocket on every stroke at first will suck but you should be able to adjust your technique to minimize that. Maybe look for blades with a pointed end to give you more room to work. In these situations I look at the cost a shop would charge (it might be $500 here?) compared with the cost of the tool to do the job (including blades, under $100). Also, you'll end up with a tool that you'll wonder how you ever lived without it. Go for it and good luck!
David A. Warr
i had to do this job on my Renegade. I had to use a hacksaw in my hand. It took me 45 minutes to cut through the bolt. Luckily the other bolts weren’t seized.
