sagging
sydbro
Sykesville Md
I have the frankenlift premium 2 and I installed an ARB front bumper and Warn winch. Now the front is sagging. Any advice?
Did you get the HD coils?
It doesn't matter anyway you will loose height when adding more weight,it's going to happen no matter what.Just HD coils prevents the amount of sag over the medium and light coils.
If you want to gain back the height just do a small clevis lift and call it a day,that's what I did when I added my ARB/winch combo(I lost a little less then 1/4").
sydbro
Sykesville Md
Honestly I thought the HD springs came with the Premium 2 kit. I didnt specifically request them when I orded the lift so I guess I dont have HD. Not really sure if I got the medium or light duty
Pretty sure the franken lift comes with HD springs on the front. When I called boulder bars they told me they didnt even have med springs but that may of changed.
sydbro
Sykesville Md
guess i will just bite the bullet and do a clevis lift. How many conduit nuts would be safe?
KJ04
Grafton, Ohio
The conduit nuts are 1/8" thick which will equal 1/4" in lift. 2 = 1/2", 3 = 3/4" .
sydbro
Sykesville Md
OK, what am I doing wrong here. Tried to do the clevis lift and I could not get the strut up in the clevis. They would not separate. I disconnected pretty much everything and could not pry them apart. Any advice?
kj924
Prince Edward Island,Canada
pics2.gif of the progress so far. You may have to take the strut right out. I know I couldn't get the strut to separate from the cleavis completely.
sydbro
Sykesville Md
no pics now. I got so frustrated that I gave up and put the darn thing back together. If I take the strut out that means I gotta fight with that evil lower clevis bolt again and I was trying to avoid that. But here is what it looks like now
I usually need to take the that bolt out that connects the clevis fork to the lower control arm to get them apart. Thats just the way I do it though.
Ive got two conduit nuts in mine and would not put any more in it. Mostly because I would get Upper Ball-Joint Contact but also b/cI do not feel safe with that little of the clevis being clamped in the fork.
Treyz02KJ
Oklahoma City
Just get something really heavy in the back... Got any spare subwoofers, or big screen tvs in the house?
KJ04
Grafton, Ohio
The clevis fork has to be removed to install the conduit nuts. You could just loosen the upper clevis bolt, have a friend pry up with a crowbar measure 3/8" and tighten the clevis bolt. I've run mine for years that way and it has never slide back down in the clevis.
sydbro
Sykesville Md
I was thinking I could cut the nuts in half, that way I dont have to remove the strut completly out of the clevis. I would put one half on the front and one half on the back (). Does this make sense?
