Rotor Recommendation wanted
styng88
Central PA
I'm looking for a decent set of aftermarket rotrors because I don't think 50k is that good for a set to need replaced. I've read some bad things about drilled, that some come apart after a while due to the weakness from the drilling. Has anyone experienced this? I was thinking of some slotted rotors thinking the reduced heat would make them last longer.
2003KJ
Planet Earth
50K is outstanding for an Automatic vehicle. I got about 27K on mine before the pads and rotors had to be replaced. I went with regular Napa pads and rotors, and they work better than the stock ones did.
50k is good for pads, not good for rotors. I do not know of any good rotors, I would like to know of some though.
ccattie
Smyrna, DE
In my Lightning club we could buy rotors at http://www.rotorpros.com/. You can get dimpled (holds up better than cross drilled - unless its cast that way) for real cheap. Even though they don't list Jeep theyre worth dropping a line to. They'll even paint the inner part to match certain colors.
-c
