Request info re my KJ, 15" wheels?
mtbskierkj
new york
Hello all, I am going to have a 2 1/2 inch suspension lift installed on my 2007 Liberty. I would like to put 31 x 10 1/2 inch tires on it. Can I put 15" rims? I plan on putting black steel rims on it.
Any suggestions would be greatly appreciated...
kj924
Prince Edward Island,Canada
I run Soft 8's on mine with the same tire size you want, mine are 15x8 with 4" BS. I run the Cragar rims because I know that 15" rim will squeak by the caliper and not rub. Cragar Soft 8's are nice and cheap too at $39/rim. :D
What wheels are you planning on getting? The D Windows look good too.
long_tall_texan
DFW, TX
I am running Cragar Black D's in a 15x7 with 4" BS. Ran 31x10.50's for a while. Now running 32x11.50 on the same rim. Pretty much any steel 15" rim will work. If you go alloy wheels, you need to move to 16" to clear the calipers.
Porkchop
Troy Mi
Alot of libertys came with 15" steel wheels when new with no lift. So its more like lift+backspace+ tire size = ? clearence.
jguthrie
Bay Area, CA
NM, Found your pics!
Are the tires in your signature picture the 10.50 or 11.50? I am probably going to copy yours as it looks almost perfect other than you never seem to upload any bigger pictures.... HINT!
Off the top of your head, do you know the overall diameter of those two tires (10.50 and 11.50) that you used?
No Liberty's came with 15 inch steel wheels when new sorry
Also a lot has to do with type of lift. What are you getting, some advertise 2.5 inches but that is not what you get in the end
