Replacing rear lower control arms
jeepguy4276
Fargo North Dakota
On the passenger side does the exhaust need to be removed or is there a trick to removing the front mounting bolt? The bolt head faces in towards the exhaust and I don’t see how it will come out with the muffler there. It’s all stock. Any ideas?
One of two ways I do it, one is to just pry muffler over
or
loosen bolt, pry part way out, cut off replace with new one ( 3 or 4 bucks at dealership )
Install the other way
Aceofspades
Buffalo
Like Tom said or even try using the jack to see if you can push it up as far as it can go. Might get lucky
Myke
USA
I was able to pry the exhaust to the side and then flipped the bolt for reinstallation. If your bolts are old/rusty I would just replace them.
jeepguy4276
Fargo North Dakota
I just spent the money and got new bolts. They aren’t cheap. Total at the stealership with nuts and an additional 2 small bolts came to $40 or so. But now I’ll just cut both of them off since they are pretty frozen and all crusty. It’ll make the job easier in the end. I hope.
40 bucks ?? last ones I bought nut and bolt was 4 dollars and a few odd cents each, less than 5 each, and that was at dealership.
bigtexasthriller
Texas
Oh, I see now that you don't have that in your area.....man, it's impressive that you're doing this yourself....sounds like a tough diy fix....
Very easy, 10-15 minutes max , only 4 bolts
Unless you are silly enough to still have sway bar on yet:happy175:
Aceofspades
Buffalo
Best mod ever. Ditched both of mine. Those inside bolts sucked Impact wouldn’t fit. Never wanted to do thst again
