Come to find out i do have the gas version with the lower lbs springs but i can't see any spacers on the libby i don't know if all of rustys 2.5 kits come with spacers in other words the day star spacer kit if not can i put them on ???
Ok, I'm going to try and take a shot at all your jibberish, and see if I can figure out what you're asking.
1. Come to find out, I do have the gas version with the lower lb. springs.
Since your signature states you have a 2005 CRD Limited, one could assume that you purchased a used 05 CRD that came with a Rusty's coil lift for a gaser.
2. But, I can't see any spacers on the Libby.
If it is, indeed, a Rusty's coil lift, there are no spacers.
3. I don't know if all Rusty's 2.5" kits come with spacers.
Rusty's 2.5" spacer kit has a metal spacer above the front strut and a poly spacer under the rear coils. Then there's the 2.5" coil spring lift that comes with 4 coils, 2 struts, and 2 rear shocks.
4. In other words, the Day Star spacer kit.
To my knowledge, Rusty's doesn't sell the Day star kit.
5. If not, can I put them on?
Put a Day Star spacer kit on in conjuction with a Ruty's coil lift?
Give me some feed back on this, if I'm getting warm.
