Replaced headlight bulbs
megatone
California
No biggie. First one took 10 minutes to get it installed......second one took 30 seconds.
Basically, when installing the new bulb, it is easiest to pop the bulb in the headlight housing first (the rubber o-ring on the bulb will hold it in place) then install the lock-ring, then push on the electrical socket.
The first bulb I installed, I tried to install the bulb, lock-ring and wire socket all as one unit.......it was difficult lining up the bulb with the hole and simultaneously lining up the lock ring tabs while maneuvering the wire socket around in such a confined area.
CactusJacked
Chicago Suburbs
Not hard, once you've replaced them before. Were you a headlight bulb replacement virgin? ;)
Since you were giving a how-to, what you didn't mention is to not touch the glass part with your bare hands, as the oils from your skin can create hot spots and shorten the bulbs life.
Birdman330
Des Moines, Iowa
I wear gloves when I do headlight bulb changes. Sometimes I've heard but don't endorse that its never a bad idea to take an alcohol wipe to the bulbs as well just to be sure when you install them.
M38 Bob
Arkansas
And some folks jack their vehicle up, just a certain way, just to make sure they get 12 more drops of oil out at change time. Neither procedure's really necessary.
Sent from my iPad using Tapatalk
M38 Bob
Arkansas
Been changing H-bulbs since they first went in use, knew from shop specialty magazines the requirement not to handle. Haven't damaged one yet. But then, I can't do a proper job of scratching my **** with gloves on.
