Recovery points
Tog
AU
I did a search for this but couldn't find any information. Where does everyone get their recovery points. Only really wanting front ones the existing ones are also mounting the nudge bar but the hole is so small i cant fit a bow shackle through
You'll likely have to ditch the nudge bar. Mopar tow hooks are the easiest to put on. They work good enough. I used to have them. Check the For sale sections here, LOST and eBay. You can get them for ~$100USD new.
JasonJ
Michigan
You may be able to mount recovery shackles to the front using that mod method where you weld 2-4" drop hitch receivers to the factory style recovery hook brackets.. You'd likely need to cut reliefs into the plastic bumper cover, but if you go with large enough drop receivers, you may be able to clear your push bar.. have your shackles then on either side of it.
Just a thought.
Tog
AU
These are the existing mounts the both bolt up the nudge bar and have the eye for connecting tow strap. The hole isn't big enough to receive the pin on a 2.75 ton bow shackle. Pin is 20mm a little bigger than 3/4 inch.
