Rear window wiper issue
Offroad Bob
OffroadBob
Chattanooga, Tn
I have an 02 Liberty Sport with the 3.7 V6 and 4x4. Recently I noticed when I braked, the rear windshield wiper would activate. The wiper would generally make 2 cycles before turning off. I braked several different times and the wiper activated. It seems with light brake pedal pressure it owes not activate. If I apply moderate pressure the wiper activates. Anyone have any idea what might be causing this ?
Just hangin' out.
Sounds to me like the brake lights are shorted to the rear wiper circuit. Only logical explanation I can think of. Given the way things are wired up back there, I would suspect it is the driver side brake light wiring which is closest to the flex tunnel that has the supply to the wiper. Will literally have to pull the interior trim panels and physically follow the wires manually. Once the damaged area is found, a bit of treatment with proper electrical tape and you are back to normal. I would follow the brake light wires from the bulb back first. Mark it with a bit of colored tape or the like. Next, follow the wiper wires from the inside of the swing gate to through the flex tunnel and to where it meets with the brake light. That will be where the source of the fault is most likely.
