Rear window problem
trazman
Slovenia
Hello guys, could anyone help me to solve this problem? On the picture you can see what happened... Because of this now the rear window opens by his self... I dont know how to repair it, i tried with a special glue, but it didnt help...
Billwill
White River, South Africa
Buy a new part?:freak3:
You would need a flexible type of adhesive especially for rubber.In SA here we have a product called "Pratley Wonda Fix Car". It is a black epoxy that you mix together and forms a strong rubber-like bond. I am sure you can get Pratley products in the USA and Europe (dont know about Slovenia!) as their products have been used in the Space Program.
Failing that, what I would do as a temporary fix is try to "stich" the pieces together by means of a large sewing needle and either nylon fishing line or fishing steel trace.:shrug:
Akedos
Elmira, NY
A two part, flexible epoxy might fix this if you can't replace the part. I'm a firm believer in 2 part epoxies myself. Loctite makes one, but as stated above have no idea about availability in Slovenia.
