Rear upper control arm...
BrianB44146
2006 Jeep Liberty purchase a few months ago. Replaced a bad upper control arm while doing a two and a half inch lift. Have the Jeep on a lift today I noticed the upper bushings are torn and falling apart already. Is this common when the Liberty is lifted only 2.5 inches?
The cheap ones are pure junk from the get go, go at the very least Moog, MOPAR is way better
I had to run one of the cheaper ones years ago due to backorders on MOPARs, lasted a couple of months
FWIW, I'm running a Napa Supreme one (think it's made by spicer), one with the blue boot, been there a few months and on a few off road trips, it's been good.
The MEVOTECH CMS25156 has a blue boot also and its half the price of the napa unit. Wonder if its the same thing?
Moog bushings are just $21 on amazon, not sure how tough it is to get the old ones out. Ive got a press so I may give it a go.
Yep, that's the same one. Oreillys has it too. I just got it locally since I figured if it breaks it'll be easier to swap out. I think most people have issues getting the bushings out, the arm just bends.
65Corvair
Iowa
I tired to press them out with a ball joint press a few years ago, and it ends up crushing the control arm. Let me know if you have better luck.
Not worth trying
duderz7
Weiser, ID
I did it successfully once with a shop press, but it was finicky to say the least. I wouldn't bother or suggest anyone else does. It was tough keeping it from collapsing like a pop can and mine is rust free.
XWrench3
i have never done a lift on anything. but i have worked with a few guys that did. of course that was 20 years ago, so things have changed. but it seemed like a lift kit meant finding answers for things that went wrong because of the lift. can you maybe make a sturdy spacer that would allow the original geometry to be maintained?
Abbas
Hercules, Ca. USA
I have Moog bushings that have proven its durability for me. I installed 2' inch lift kits and two years ago and I decided to replace bushings for added peace of mind. It's just around $21 at Amazon. Another one to consider is Mevotech parts if you will be replacing kits. There's a link article comparison between the two, those are good aftermarket parts for Jeeps.
Offroad Bob
OffroadBob
Chattanooga, Tn
I replaced the original upper arm with a NAPA high $ too. That was last Nov and it’s already bad. I ordered a complete rear setup from Iron Mtn and it arrived today. Going to install Saturday!!
