So I replaced my cracked radiator this weekend. Everything went well, no more leaks! But I forgot to to do something... I didn't put the wires in the guides located on the edge of the fan. Basically the two power lines to the radiator fan were dangling (they are actually grouped together in a sheath).
I was driving it back home from my dad's (where I did the work) earlier today. It's about a 2-hour highway drive and in Ohio today it got pretty toasty. I turned on the A/C and the air was not very cold. In fact, I had to roll down the window so I wouldn't sweat to death
. After arriving in Kentucky, I checked the engine to make sure I wasn't having any issues. Low and behold I see the two lines coming from the fan laying right next to the pulleys and belts. I'm lucky the lines didn't get tangled in the belt and cause serious damage. The lines definitely came in contact with the belts. The sheath is torn in a couple spots, there are also a couple spots where the two wires are now exposed. There doesn't seem to be any disconnections between the wires. BUT the fan doesn't spin. I believe this is related to my A/C not getting cold? I turned on the Jeep and cranked up the A/C...no fan spinning.
I don't believe there is an easy way to replace the power cord to the fan because it is directly attached to the fan motor. Do you think I should try splicing the cable and take out the sections of exposed wire? Anything else I should test/check to see if the fan will work?
I'll try to upload a pic tomorrow. THanks!!
