Question about 4WD when in 2WD
kjpaguy
Pittsburgh, PA
'05 Renny with auto trans. Nope, no full time. Just 2HI, 4PART and 4LOW. And N obviously.
Robsoma, your only option from my understanding is the selectrac has an extra option of 4part, the command trac only has the 4hi or 4lo, which gives equal power distribution to the front and rear wheels. both transfer cases offer the 4hi and 4lo, so you have the command trac
I wish mine had the select trac cause when its raining and hydroplaning is an issue the 4part time helps or when going around a bend
please someone correct me if I am wrong
Emoto
SE Mass
SelecTrac has 2WD, 4WD Hi, 4WD Lo, FullTime 4WD.
And yes, the FullTime 4WD option is great for road use in the rain or any wet/dry/slippery road conditions not quite bad enough for regular old 4WD Hi.
rockymountain
Spencerville, IN
You need to change part to full. 4full in your post instead of 4part. Full time is actually the extra mode you speak of.
kjpaguy
Pittsburgh, PA
okay so the slectrac has 4hi and 4 full time, wasn't sure how it looked since I don't have one
just read the transfer case section in the jeep thread above and they described a little differently
thanks for clearing it up
