Prelowered 2002
sootie007
Clermont Florida
Can you tell by the spring part number if your 2002 Lib is a pre lowered unit ? If so what is the p/n for that spring or were the lowering changes more severe than just a spring change ? J
ThunderbirdJunkie
Bronze Supporter
Newport, KY
It was a spring change, but the coils will cost you more for OE units than Old Man Emu coils will.
Might as well lift it, after all, you're after clearance ;)
ThunderbirdJunkie
Bronze Supporter
Newport, KY
March 02 or before that for build date, yours is a prelowered KJ.
Beyond that, talk to the folks at the parts counter.
There are so many different PN's for OEM springs and many of them may have been superceded when the KJ was lowered.
Good luck finding the info you want.
timmer
South Louisiana
This is what I have listed on my build sheet for my '02:
ZCGP - Spring - Left Front
ZCVP - Spring - Left Rear
ZRGP - Spring - Right Front
ZRVP - Spring - Right Rear
Not sure what it means though.
sleeve
Woodward Ave
Tony's correct...
If you still have the Factory stock springs - they will be "taller." As soon as you replace any one spring, all of them will need to be replaced, because Chrysler only delivers "short" springs.
I believe the Pre lowered KJ's had the 4x4 badge on the side, not on the gate.
Other than that, check your build date. If it's before April 12, 02, you're pre lowered....:)
sootie007
Clermont Florida
Build sheet - where is it ?
Where can I find my build sheet ? Thanks J
sootie007
Clermont Florida
Wow what a ton of info they give you here is mine...ps anybody got a REAL early build date like mine ? Mine was built "9-2001" ! Had to be one of the first . J
"We have reviewed your email regarding the Build Sheet. We appreciate
the time and effort you took to write to us. In response to your email,
we would like to inform you that according to our records, your vehicle
was equipped from the factory with the following:
Cloth High-Back Bucket Seats
Dark Slate Gray
Convenience Group I
Power Convenience Group
Monotone Paint
3.7L Eng(EKG)/4Spd A/T 45RFE(DG4)
136 Amp Alternator
525 Amp Maintenance Free Battery
Power Front Disc/Rear Drum Brakes
Reclining Front Seats
Rear 65/35 Folding Split Seat
Traveling Inboard Seat Belt Buckle
Child Seat Anchor System-LATCH Ready
RR Head Restraints Outboard Seating
Next Gen Multistage Front Air Bags**
Center Rear 3-Point Seat Belt
Floor Carpet
Cargo Compartment Carpet
Cargo Tie Down Loops
Plastic Swing Gate Trim Panel
Front & Rear Floor Mats
Cargo Trim Panel w/Storage Net
MOPAR Bright Door Sills
Door Sill Scuff Pads
Passenger Assist Handles
Driver Assist Handle
Base Door Trim Panel
Full Length Floor Console
Removable Ash Tray
All 4-Speed Automatic Transmissions
Multi-Speed Auto 45RFE Transmission
Lock-Up Torque Converter
Command-Trac Part Time 4WD System
Dana 30/186MM Front Axle
3.73 Axle Ratio
Corporate 8.25 Rear Axle
3.7L V6 Engine
Tinted Windshield Glass
Front Door Tinted Glass
Deep Tint Sunscreen Glass
Flipper Swing Gate Glass
Rear Window Defroster
Rear View Day/Night Mirror
Sun Visors w/Illum Vanity Mirrors
Power Mirrors, Fold-Away
All Vehicles W/Power Mirrors
Remote Keyless Entry
Air Conditioning
Route 89 - CSX, Selkirk, NY
Instrument Cluster w/Tach
120 MPH Primary Speedometer
Var Intermittent Windshield Wipers
Rear Window Wiper/Washer
Cigar Lighter
Dual Note Electric Horns
12V Auxiliary Power Outlet
Auxiliary 12-Volt Rear Power Outlet
Glove Box
Power Windows, Driver One-Touch
Speed Sensitive Power Locks
STRIPE/BADGE/MOLDING/COLOR
Illuminated Entry
Headlamps On Warning Chimes
Ash Tray Lamp
Map/Dome Reading Lamps
Cargo Compartment Lamp
Headlamp Off Time Delay
Halogen Headlamps
CHMSL Lamp
Front License Plate Bracket
Body Color Grille
Black Windshield Moldings
Gray Fascias
Belt Moldings
Black Door Handles
Jeep Badge
4X4 Badge
Sport Badge
Roof Rack
3.7L Badge
Liberty Badge
50 State Emissions
EVAP Control System
Low Emission Vehicle (LEV)
18.5 Gallon Fuel Tank
Power Steering Cooler
Speed Control
Bright Silver Metallic Clear Coat
All Radio Equipped Vehicles
AM/FM Cass Radio w/Changer Control
6 Speakers
Fixed Long Mast Antenna
Power Rack and Pinion Steering
Leather Wrapped Steering Wheel
Normal Duty Suspension
Tilt Steering Column
Full Size Spare Tire
Outside Tire Carrier
P215/75R16 BSW All Season Tires
Goodyear Brand Tires
Matching Spare Wheel
16X7.0 Lux Styled Steel Wheels
All Steel Wheels
Front Suspension Skid Plate
Grocery Bag Hooks
Protective Coating and Remover
5 Additional Gallons of Gas
Spring - Left Front
Spring - Left Rear
Spring - Right Rear
If we can be of any assistance to you in the future, please feel free to
contact us. We value you and your business. "
sootie007
Clermont Florida
Tony if Junkie doesnt get you a pic I will try .....by the way on my option sheet what is
" Route 89 - CSX, Selkirk, NY" ?????? Is that the dealer it was shipped to ? J
I don't think so.....that's what holding place it was sent to before being delivered to the dealer....mine was Iowa....:)
ohaness
Western NY
Interesting...my build date is 6/25/01. Here is what Jeep sent me when I inquired:
Thank you for contacting the Chrysler Customer Assistance Center regarding your 2002 Jeep Liberty.
In response to your recent reply, we would like you to know that as per our vehicle information database the build date for your vehicle is June 25, 2001.
That seems too early to me but maybe because it was a new plant in Toledo building the Liberty for the first time.
Wow.....must be one of the first if not the first....:eek:
