Power steering pump and high pressure hose
Discus
I have another problem. Tried to take the high pressure hose off but the end that goes in the pump won't unscrew. Instead, the insert/nut at the pump is coming loose. I don't have access to hold both the insert and the nut of the hose itself.
So I figured I could take both off and separate them after they are out but then a spring and a part came out....
Can I just put them back in? Is the order on the picture ok? Or is there more to it?
Any help would be appreciated.
Thanks
Discus
Thanks
Just found the 2nd image while searching the net. Should I just put it back in in that order?
Discus
I'd just put them back in that order. I doubt it'll be a problem.
Iwill try tomorrow , not obvious though. Limited space to work with and the hole is pointing down. Will have to push it in and screw it at the same time. Thanks
Discus
Well I took the grill, rad and fan and I was able to put it back together . Tomorrow I'll fill the power steering system and see if it all works. I changed the water pump also.
