ATF+4 full synthetic,ATF+3 is not and is no longer used by Chrysler.
Your PS system is very different then a trans.If you read up on why you shouldn't use ATF in a PS system(google is your friend) you wouldn't want to run ATF in the PS system also.I don't,I use synthetic PS fluid,specifically made for PS systems.
tjkj......Ok This was getting a little confusing because we are talking about different MY KJ's which take different fluids per the owners manuals. For instance my 05 came with ATF+4 and I have no noises or issues so when I get around to changing it I will continue to use the ATF+4. It is a quality synthetic anyway as you said.
So those with other MY that their owners manual says something different, (02-04 MY) they should continue to use what their owners manual calls for, or if they do a flush, then they can use the ATF+4???? Is this correct??
Also, what are you useing out of curiosity?
