Passenger water leak help
claggie
Castle Pines, CO
I have a 2006 Liberty. When I run it thru an automatic car wash, I am getting water in the passenger footwell close to the door. It appears to be coming in from the passenger door pillon. The water is under the carpet and close to the seat and the door.
Any ideas on where to check for the leak? I've already sealed the air filter intake and I'm fairly sure this is not my issue. I don't have any water under the glove box. The water is closer to the door and seat in about a 12 inch area.
Thanks.
most likely your sunroof drains are clogged.
There's a hole for the drain at each of the 4 corners.
if you detract your sunroof glass so it is fully open, you'll see a small hole on the corner.
You can use compressed air through it or use something to snake it.
Someone here just recently used grass cutter nylon line through it to snake it.
You'll want to make sure to clean out any debris out of the sunroof area as well.
This is not from a liberty but it looks similar.
I'm not sure about the rear facing drain holes but I think you might have to remove the glass to be able to see them. If you're using some sort of snake, you could prod and pray that you get it in the hole.
I'm just wondering what happens if you get your snake stuck in the hole?
I picked the wrong day to quit drinking..
55634[/ATTACH]"]
Carry on..:gr_grin:
