When I bought my 2005 Liberty with the 3.7l gas engine, it came with oil leaks. The first and largest was the power steering pump so I replaced it and the high-pressure hoses and that has cured the most obvious and largest leak.
I have not thoroughly cleaned the engine yet but there's maybe a clue to where the remaining leak is coming from if you're familiar with these trucks, and I'm not. If I crawl under the Jeep, there's always a drip on the end of the v shaped trough, that plastic piece meant to catch spills from changing the filter. I can reach in there and wipe it clean but in a day or two there will be a fresh drip on the end of it. The oil does not seem to be coming from the filter. The filter is dry on the outside.
At first I thought the pan gasket was leaking but I don't think oil from there could make its way to that trough. Does oil in that tray definitively point to a common leak these engines develop like a front seal? I would love it to be anything other than the pan gasket. I understand that's a miserable job.
TIA
TIA
