New to the Liberty -- how many miles can I expect
luv2rv
Hi, I'm new to the Liberty and shopping for a KK and I'm wondering how much I can afford to spend and a lot of that depends on how much life is left in her.
I think I found a good one with oil changes about every 5k, and a transmission change at 74k. It has about 115k now and I would plan to change all the fluids once I get it and would continue regular maintenance.
Do you think 175k is reasonable? I'm sure there are forum members here over 200k. Just wondering what a reasonable expectation would be and thought I'd turn here first for some real-world advice and experience. Thanks : )
Just hangin' out.
Mine (well sortra mine- I gave it to my kid) has over 300k on it. Still the factory drive train. 200k of that is mine and about 50k miles off road and bouncing through the desert.
If the price is right, nothing wrong with that mileage.
Like any vehicle, do your maintenance, keep an eye out for rust and you will do just fine with it.
You can check out some of my Liberty adventures here on the forums. The Sciencemobile is a beast.
luv2rv
Thanks Johnny--it definitely sounds like you got your money's worth : ). There's a local independent dealer with 2 Libertys I assume he bought at auction. One is priced at 5k, the other at 6.5k. Both prices are below KBB retail for their year and mileage so they sound reasonable. I'm interested in the 2008 for $6.5 with 115k miles. It looks very clean and has the towing package. I have a small bowrider so I need that.
I'm all ears if anyone has some advice on typical things to look for on a test ride. I googled the dealer and there were the typical range of reviews. A couple of really unfortunate experiences, and a lot of positive reviews, several of them sounding fake, so they probably are. I've thought about taking it to a mechanic, but I'm not sure if they'd do much more than just check fluids and go for a short test ride. I have a scan tool, so I'll confirm that there aren't any recently cleared codes. I'll check the trans fluid for color and oder, check under the oil cap for foam, check the dipstick for any discoloration, and verify it shifts through all the gears smoothly. Searching for any advice on what else to check. I've read the window controls can be problematic. Any other Liberty-specific things I should look for?
Luke
Interloper
Bancroft, Canada
I’m confident mine would still be kicking’ if it wasn’t for the (body) rust. Suspension, thermostat, steering rack was all it needed over its lifetime.
Worn suspension, easily and relatively cheaply upgraded. Rust if it's been on salty roads.
229k miles on my 08 KK now. I recommend changing your oil every 3000 miles to keep the sludge under control. These Jeeps can last a long time if you keep up on maintenance. If you live in a state where they use salt on the roads, get a monthly unlimited car wash subscription for $20 that includes underbody wash, and keep the salt at bay.
cwbyflyer
Krum, TX
285k on it now - bought it with 154k about 10 years ago. Ended up replacing the transmission at 277k, but other than some small annoyances (window regulator failures and a gate switch that keeps dinging) it's going strong.
Rokk
The 3.7 is known to blow head gaskets and sometimes valve seats if overheated too much, so look out for stop leak in the radiator and take care of your cooling system. Don’t buy one with the convertible top, I don’t remember what they’re called but you’ll know it if you see it. The hvac blend doors have plastic gears and if you need to do a heater core or ac in the dash it requires tearing out the entire dash. All these parts are fairly cheap and the vehicle is easy to work on in general. Mine has >180,000 and runs like a champ. Terrible gas mileage though.
2008Liberty175k
201,000 miles, still going strong. Had it for 5 years and put nearly 60,000 on it.
There are minor annoyances I have decided I can live with (heating system is basically crap but I'm unwilling to tear the dash apart to remedy - flushed heater core, replaced radiator & coolant & water pump) but the A/C still blows strong, even if it only comes out the bottom or top vents.
I had a parasitic draw that I think I've recently solved, I blame a wire that snakes back the frame from the positive terminal the previous owner had installed to the rear hitch harness. Jury is out on whether I've solved it but if not, a battery tender to plug in is a simple interim solution.
Check rear upper & lower control arms for severe rust (mine on drivers side top was nearly rusted all the way through)
Mine has a tendency to eat brake pads (Drivers side front) so I recently replaced all rubber brake hoses and brake fluid. Jury's still out whether this fixed it but all calipers were replaced 2 years ago.
Change engine oil and filter regularly (Oil filter is a real pain to get to)
Long story short, if you're handy with tools and enjoy performing maintenance (as I do) you'll likely enjoy the Liberty. There are tons of youtube videos out there that are huge helps when it comes to performing some maintenance items. Paying a shop to do some of this stuff can tip the scales unfavorably in the "value" category as the car's just not worth that much in resale value.
Overall, its a great driving vehicle. I didn't expect to like it as much as I have; strangely enough, the longer I own it, the more I enjoy driving it. I love the turning radius compared to our other cars.
AFT2008KK
I’m late to convo. But 150K on our 08. Been in family since new. And all over SW and even Black Bear Pass. Definitely keep up on maintenance am”nd at these ages (over 15 y.o.). Get ready to replace worn out parts. Fuel injectors, coils, etc etc. 3.7 is realistically easy to DIY. I like it better than the 3.6 in our ‘12 JK. Happy Trails!
Got pics from Black Bear Pass? (taken by your passenger and hopefully not you!) :p
