kb0nly
Deleted...
Just installed my new Gatorback belt and Gates tensioner... Ahh peace and quiet.. The Squeekity is gone when the engine is cold.
FYI... If you haven't checked yours check it. When i took it off i gave the tensioner pulley, the ribbed one, a spin and man is that bearing ROUGH.. Is has a nice whine and grind to it, SHOT...
The only symptom i had was a light squeek for a half minute or so when it was cold, i thought it was the power steering pump. But since it was at 58k and everyone talks about the tensioner self destructing i replaced it. What a difference.
..where u get em from?
Unless you can find a good price locally, i couldn't, get them from RockAuto.com...
Same here... the "I couldn't" threw me off the first time I read it.I read it as I could not get em at Rock Auto
Yeah... sad isn't it? But, oh well...Ouch... Thats a LOT more than i spent for a Goodyear Gatorback and Gates Tensioner...
Actually for about $90 with shipping i got the belt, tensioner, trans filter and gasket kit...
The OEM EPDM belt will out last the gaterback belt by at least 100k.I had a gaterback belt on and it didn't make it 10k before it was cracking badly,it's still a old school poly belt with a design life of 20k-30k if your lucky.
Different operating conditions dictate belt longevity,some areas a belt will last longer then others.If the OEM belt should run 100K more than a Gatorback which you say can run 20K, then why did I have to change out my OEM EPDM belt at 60K if it's suppose to run for 120K?
The OEM belt was cracked and beat up and starting to shed some of it's width. I replaced it with a Dayco belt and after 20K it still looks new, no cracks.
Good luck with a dayco belt,the worst belt you can install.
I replaced my belt a couple of years ago just after I got my Jeep. It had about 50k miles on it then. I put an original mopar belt on it cos we don't have the wide choice for spare aftermarket parts over here that you guys have but they wanted £150 for the tensioner!!! Needless to say it didn't get one. It has about 67k on it now and still quiet so hopefully it will be ok.
Maybe I need to become an aftermarket Jeep parts importer? Hmmmmm? headscratch.gif
EPDM belts are designed to last 100k,that does not mean all will as you well know.Poly belts(dayco and gaterbacks) have a design life of 20k-30k.Just shot your own 100K arguement in the foot eh?
The Dayco was all I could find in this back water berg. The dealer didn't have one in stock when I needed mine. Hell man, they don't stock any Liberty bits. All of the parts I've had to get through them have had to be ordered from a magical parts depot somewhere.
