NEED ADVISE for when my grabbers wear out.
seabass1858
hanover pa stationed in Ft Benning (GA)
I will be looking at ether keeping the IFS and go with JBA front steel diff along with je-reel hd cvs, or I will be doing the SFA setup. I only plan for 285-75-16s, (33x11.3x16) with 4.56 gears, so reusing my front truetrac and installing it in the jba setup sounds promising at the moment. I have a full width HP44 out of an f100 with drum brakes so I'm not sure what I want to do. If I stay with IFS I will be doing jba long arm for the rear. I already put superior axle shafts in the rear so I know its plenty strong.
First if only wanting to go to 33s why?
Only gaining 1/2 inch more height
Also depending on how you are going to use it do you really need the JBA steel diff?
I'd look at the cost of the diff along with regearing again the front and rear and what you are getting in the long run
