mrlavalamp
I don't think you can rely on the results of your old tests in comparison to your newer advice. The compression test was a year ago, you probably need to disregard that for now as a primary symptom, or go and have the recommended compression and leak down tests done.
Pcm and compression testing are not related, compression tests should be completed with spark plugs removed so engine is not running.
List in the sticky says that code is high oil pressure. If it does that when it's cold at startup but goes away when engine warms or temp outside warms, then it could be your type of oil.
What oil are you putting in it? Last change?
