Need 45RFE help.
Jacob789456
San Diego, CA
Hi all, I changed, or am in the process of changing my 45RFE's fluid and filters. I bought Wix filters for my 2wd 03' liberty and I am having difficulties removing the main filter seal from the valve body. Is there a trick to this, or is a special tool needed? Also I forgot to pre-fill the spin on filter before I put it on and now it is torqued down unfilled. Do I need to remove this and fill it, and if so do I need to buy another filter because the main rubber gasket was already torqued down once? Any help, tips, etc. are appreciated, thanks!
Ry' N Jen
I've done the same thing with my oil filter.
I just removed it, filled it with oil and spun
it back on. No leaks and no problems!
I can't help you with the transmission though,
I bring our KJ to the dealership and have the
****** flushed and refilled.
ridenby
Gold Supporter
Kentucky
No special tool needed, and would just button up trany and fill,check fluid level shortly after running.
04Liberty
MD
Same thing in my 545, that ring seal is a *****. You either leave it alone or I used a narrow flathead and hammer to gently squish it a bit to pry it out. Should you have filled the canister? Yes. Is it going to kill it? Probably not.
