My lift is finally installed
jelohead
NY
well, it started as a Rusty's lift......Rusty's coils, OME front shocks/struts, and the N132L OME rear shocks purchased from All J's. All J's has the exclusive on the longer OME rears. Also, 3 locknuts on each strut (clevis lift), and 1 upper spring isolator above each rear spring. It totalled 3" of lift at the bottom of the wheels wells, then the 245/75 MTRs added another 1" of lift.
J-Thompson
just south of doucheville
Your rig looks nice
we have the same rim and tire combo
did you have to space the spare out any? ours needed about 1/2" or so to keep from rubbing on the bumper real bad
also did you extend your bumpstop's?
if not you MUST if you plan to wheel your KJ
you will get some good rubbing out back at full stuff but what is more important with the N132L's they will bottom out befor you hit the OE bumpstop ,they are Longer than the OE's or the standard N132's
Your shocks are made to limit down travle but not to hold the weight of your KJ
jelohead
NY
J, i did install the Daystar extended bumpstops from All J's, i keep forgetting that i did! duh....and, no, i didnt do anything with the spare, it sits back there proud as all get-out!
jelohead
NY
nope, J, the tailgate shuts just fine, no issues at all.
