After not having dimming instrument lights for a long time in my 2003 Jeep Liberty I finally got fed up and bought a new multi function switch. Getting the shroud off was the hardest part. Clicked the replacement in place and everything worked. The problem is that I discovered that while the left turn signal works it never disengages. I can make a 180 degree left turn and when the steering wheel straightens the turn signal still clicks and flashes. Right turn works just as it is supposed to.
Must be a bad part, right? So I got a second replacement switch today and am having the same issue. Left turn never disengages. Very frustrated. I can test the switch in my hand and manually get it to click on and off so the part works.
What are the odds I got two bad parts? ... so it must mean I am the bad part :happy175: Is there a step of this install I am missing? Do I need the wheel in a certain position when I click the switch in place so the white clicky tab aligns with something in the steering wheel or something?
Any suggestions welcome - with so many posts on the multifunction switch causing weird electrical issues there must be a 100 people out there who swapped theirs out already.
Thanks.
Thanks.
