Moist headlight
Chitownjohnny
Chicago
I have one headlight that has moisture inside of it. What do I need to do to get it to stop? Reseal or use silicone.
Ya take it out and find the source of leak.
Silicone is crap long term, use a polyurethane sealant.
Also look at seal where bulb goes in.
Birdman330
Des Moines, Iowa
You may have to do a pressure check to find the leak as well. Sometimes a crack, or bad sealant can't be seen with the eye.
M38 Bob
Arkansas
One can also drill a vent hole in the lowest portion to let any actual accumulation drain. With a vent, they don't seem to hold moisture droplets as bad either.
CalcityRenegade
Calgary
Make sure the light bulb is correctly seating and sealing and check for any cracks in the housing. If non I would rip em apart and reseal them and know they are good. Or replace em if you find a good deal! Now is a good time to do a projector retrofit lol.
Birdman330
Des Moines, Iowa
Yup, bake it in the oven or if you have a cardboard box and a hair dryer you can do it that way there as well.
