Misfires and hard idle -04 liberty
joep
Michigan
My 2004 liberty, with 105000 miles, is throwing two codes right now p0300 and p0132, i have also gotten p0420. Since i got her a year ago i have had the O2 sensors replaced twice, a new cat put in, new spark plugs all trying to fix these miss fires and the O2 codes. but nothing works. Any ideas what it could be?
Snail Farmer
Fairmont, MN
A couple months ago, I fought with the same thing. I spent tons of money replacing things. What it came down to was the O2 sensors. I replaced them the first time and it did nothing to help. Once I installed NTK O2 sensors, it fixed everything. So I would recommend if you didn't replace your O2 sensors with NTK, get some before you waste tons of money like I did. The P0420 code generally means a bad cat. Hopefully it's throwing that code as a result of the O2 sensors. But being the O2 sensors are cheaper, I would definitely go that route first.
