Hello all,
I have read many posts on this topic, and since most of them seem to be old, I thought I would start fresh and see if anyone has found a solution for this problem. I am working on a 2002 Jeep Liberty Sport, V6, with approx 180000 miles on it. About 3 months ago, I was driving on the highway, Liberty running fine, when it started missing like 2 cylinders had dropped out of it. It acted like a severe miss, and had no power. The check engine light immediatly came on, and when I would try to go up even the slightest hill, it would start flashing. When I got it home, I had an Autozone check it, and the codes indicated a misfire on 5 and 6. I changed the plugs and coils for both cylinders. #6 plug looked OK, but #5 plug had the tip and the electrode blown off of the plug. Changing the plugs and coils made it run much better, but the check engine light remained on, and I still had a slight miss. I checked the connection where the plug attached to the coil, and it did not seem to be locking in place on either side, so I zip-tied them securely in place. This also seemed to help, but the check engine light remained on. I have been trying to find out what this problem is, but haven't been too worried about it because the engine seemed to be running fine. Then tonight it started missing again, with the check engine light flashing at me whenever I put a load on it. We stopped, went into Walmart, and when I started it back up it was running fine. I have read about changing crankshaft sensors, ASD relays, cleaning fuel injectors, detecting vacuum leaks, but there does not seem to be any definite answer. Has anyone found an answer to this problem? Any help would be sooo appreciated. I am not a great mechanic, but I would like to try anything I can do before I cash in my 401k for the mechanic! :secret:
Thanks for your help, Jim
