BlackPatch
Hello All...
I have a KJ Sport 3.7 with 262000 Km's on the Clock.
Just started seeing milky residue in the Oil filler neck.
Driving conditions:
I drive 17 Kms to work / Home in the morning and evening. (About 15 Mins)
Some short trips during the day.
Temp has been cold recently, although at the moment, it is 8 degrees C and set to get a little warmer. (I live in Edmonton. AB)
What the vehicle is:
Vehicle is NOT down on power.
No white or blue smoke from exhaust.
Coolant "Header" tank is clean and free of oil residue in the coolant
Very Very Very slow leak from the bottom Rad hose to the block. (New hose on order)
Am I looking at coolant leak into the block via a head gasket or cracked head? Is this something these vehicles suffer from?
Is the PCV valve a possible issue here?
What I will do tonight is change the oil and the filter and inspect the Oil for Water. I will update.
Thanks for looking and taking the time to help.
Pete
Driving conditions:
Pete
